It is currently Sun Mar 24, 2019 9:26 am
PostPosted: Wed Aug 29, 2018 12:58 pm
Hey guys,
what are the lengths for the side stays & the front stay for 84 hobie 16??
our side stay broke & we had 2 different lengths in the parts box that came with the boat..
we want to replace them all with the correct length ones
We are running the std seaway blocks but would eventually like to get low profile 6:1's
Detroit..north of
PostPosted: Wed Aug 29, 2018 8:22 pm
1985 H-16..... Shrouds 18'11"... forestay 17'6"
PostPosted: Thu Aug 30, 2018 10:06 am
In replacing everything is it better to go all one way or the other (2009 specs vs 1984 specs)? or can you run the old bridle & pigstay with the newer frt stay & side shrouds
We eventually want to get the low profile blocks but wonder (if we go with all new ) if there is enough adjustment in the chain plates to run the newer lengths with the old seaway blocks for now.
Detroit..north of
PostPosted: Fri Aug 31, 2018 1:20 am
With shorter shrouds your mast step casting and the mast base will bind on an older boat.
JKK
83 yellow/ white decks Hobie 14 Corando turbo
82 yellow hulls Hobie 16 Cat Fever
84 yellow hulls hobie 16 Yellow Nationals
plus a few extras that I'm restoring
PostPosted: Fri Aug 31, 2018 9:03 am
ok, thx, longer shrouds it is
Detroit..north of
