It is currently Tue Jul 16, 2019 4:29 pm
PostPosted: Mon May 20, 2019 5:04 am
Hi Gang,
I hope you all have wet your hulls this season!
I have a 14 turbo with a set of early epo's and adjustable castings. My 16 has the white fiberglass I think rudders and non rake adjustable castings . Do any of you know if I could drill the epo's to work on both boats safely or would the holes be too close? I have not seen the drilling template or that might tell me everything I need to know.
TIA,
Eric
82 Yellow hull 16 '81 Boomer nationals 18.5 on GPS
83 White hull 16 No sails "Pig Pen"
PostPosted: Mon May 20, 2019 2:52 pm
The 16 and 14 both use the same rudder castings, however the holes for the adjustable vs. non-adjustable castings are different.
https://static.hobiecat.com/digital_assets/rudderdrill_FLvr0li.pdf?_ga=2.211142096.478254556.1556579139-2029119106.1505777923
PostPosted: Mon May 20, 2019 4:12 pm
Just swap the whole rudder assemblies.
PostPosted: Mon May 20, 2019 5:18 pm
Good to know that they use the same castings. I have epo's for my 16 now! I will just have to adjust the toe probably and maybe the rake we will see.
Thank you guys for the replies
Eric
