It is currently Wed Apr 24, 2024 2:26 pm
PostPosted: Mon May 20, 2019 5:04 am
Hi Gang,
I hope you all have wet your hulls this season!
I have a 14 turbo with a set of early epo's and adjustable castings. My 16 has the white fiberglass I think rudders and non rake adjustable castings . Do any of you know if I could drill the epo's to work on both boats safely or would the holes be too close? I have not seen the drilling template or that might tell me everything I need to know.
TIA,
Eric
84 14T Redline #67 Blue Hawaii faded but still working!
82 Yellow hull16 '81 Boomer nationals 20.9 on GPS
83 White hull 16 No sails "Clean and Purty Now!"
87 White hull no sails no tramp
PostPosted: Mon May 20, 2019 2:52 pm
The 16 and 14 both use the same rudder castings, however the holes for the adjustable vs. non-adjustable castings are different.
https://static.hobiecat.com/digital_assets/rudderdrill_FLvr0li.pdf?_ga=2.211142096.478254556.1556579139-2029119106.1505777923
PostPosted: Mon May 20, 2019 4:12 pm
Just swap the whole rudder assemblies.
PostPosted: Mon May 20, 2019 5:18 pm
Good to know that they use the same castings. I have epo's for my 16 now! I will just have to adjust the toe probably and maybe the rake we will see.
Thank you guys for the replies
Eric
