Bought a 88' 16 beginning of this year and have had a blast on it so far. On the fourth I had some friends take it out and break a rudder off so I figure now is the time to fix her up right. A few questions and clarifications from previous threads I've read.
What is the best method to remove stuck delrin screws? Fire? Drill it out with a long bit?
My comp tip has definitely spent plenty of time baking in the sun and lots of fibers are showing(pics attached) is it acceptable to paint it to protect further wear? If so, what paint should I use? (you'll see a picture of the luff track that I am going to replace for your viewing pleasure too)
All of my cam cleats aren't springy anymore. I've seen rebuild kits but they say they are for 93 and newer. I'm pretty sure mine are original so do you know a place that I can get the caps and base that will fit my cleats?
Thanks for all your help!
https://imgur.com/gallery/PTYY68g?fbclid=IwAR2jpg9G6FWnt63NhacbY587ZtHRTd_Zp6msdsUnEnhUw4LoFWCROT8-hTA
