It is currently Mon Mar 27, 2017 11:30 pm
 Post subject: Side Rails
PostPosted: Wed Mar 17, 2004 9:24 am
Does anyone have any idea what is best to cover the side rails of the 16.
Looking for ideas
Zip
PostPosted: Wed Mar 17, 2004 12:57 pm
Hobie Tech / Moderator
I prefer neoprene.
GT
Greg Thomas
Hobie Factory Team
PostPosted: Wed Mar 17, 2004 1:21 pm
I prefer carpet.
It's really personal preference.
Neoprene & non-skid can be tough on the rear end. Carpet absorbs water and isn't as "grippy." Both carpet & neoprene get shredded by the trapeze shock cords & knots.
Why don't you try one side of each? :wink:
Matt Bounds
 Post subject: carpet!
PostPosted: Wed Mar 17, 2004 1:23 pm
If you don't want to buy the carpet kit from Hobie, go to Home Depot and buy some of their indoor/outdoor carpet. They have a nice medium grey that looks pretty good. Also, buy a can of 3M super trim advesive. It is about 9 bucks a bottle. cut the carpet into about 6-6 1/2 inch strips and spray the living daylights out of the backs of the carpets and make sure you get the edges well. Make sure the rails are clean--you can use Acetone for that. Spray the rails pretty well, too, then wait for both (rails and carpet) to dry. That should take about 15-30 minutes depending on the temperature. Then, install the carpet on the rails. The glue works on pressure and really sticks to itself well, so you need to spend a few minutes really pressing on and squeezing the rails to get it to set. That's it--pretty easy and I have had it last for several years on my boats.
Hope this helps,
Dan
PostPosted: Sat Mar 20, 2004 6:24 am
If you sail in a sandy area, the carpet gets sand and grit caught in it- kind of hard on any body parts that slide across it. I've got a 16 with carpet and a14 with neoprene. I sail mostly from beaches, and the neoprene seems better. It shreds easier-though. Dave
PostPosted: Sun Mar 21, 2004 3:38 pm
Thanks for all the input. I had carpet before and am looking for something better.
PostPosted: Fri Mar 26, 2004 1:26 pm
neoprene is the way......
Race Them, Wreck Them, Fix Them....
 Post subject: Neoprene
PostPosted: Fri Mar 26, 2004 1:39 pm
I always have liked neoprene. It wears pretty well and has good traction, but the BEST thing is when you are derigging on the trailer and you have to lean over the side rail to reach something on the trampoline... you don't get wet as you would from soggy carpet.
All of the boats at this years Worlds will have neoprene.
