We have a couple of very special and very big machines and guys with eons of experience to make it work. To create enough heat and not melt or burn the tramp material is science and art. One machine is for a process that allows long continuous welds. It is a heat blower. It injects high heat between the layers of material as they are drawn into a set of rollers that mush the heated layers together. The other machine is called a sonic welder... actually VERY high voltage is run through blocks of aluminum that have been placed on the machines table pinning layers of material together.
Stitching will be WAY easier, but as you know... it just doesn't last as long or look as good as the welding.
_________________ Matt Miller Former - Director of Parts and Accessory Sales Warranty and Technical Support Hobie Cat USA (Retired 11/7/2022)
