It is currently Sun Jul 12, 2020 5:37 am
PostPosted: Mon Jan 21, 2019 4:21 am
Hello,
Just receive my Outback 2019 and noticied this piece on vantage seat:
Now we cannot slide the seat down like before.
Is there a technical reason or can we remove it to allow more down seat?
François - French Hobie fishing team - Outback 2019 papaya
ex: Revo 13 2007 - PA 14 2008 - PA 12 2009 - Outback 2011/2013/2015 - Compass 2017
PostPosted: Mon Jan 21, 2019 10:19 am
That limits the seat from going too low which would expose a possible pinch point above the seat. You could get a finger or clothing in to the top of the gear box if the seat went too low. All other models have a guard to cover that. The Outback did not require the guard due to the range of seat position.
PostPosted: Mon Jan 21, 2019 10:44 am
Thanks Matt,
So no problem to remove it?
PostPosted: Mon Jan 21, 2019 4:56 pm
Yes, problem. You can injure or capture a body part if the seat goes all the way down and exposes the top of the gear box. As the seat goes up...
PostPosted: Tue Jan 22, 2019 9:26 am
I'm afraid I don't catch it Matt.
What do you mean by "exposes the gear box"?
PostPosted: Tue Jan 22, 2019 4:59 pm
The photo is of the gear box with the stop / adjustment plate (stainless). I am told that this stop has been on all models, but this is just a bit higher (in the gear box). The gear box is what the front chair support rides up and down in. There is also no lower adjustment hole.
If the chair could go lower... you could see into the gear box above the seat. That means a finger could get in there. If the seat were to rise up at that time you could pinch a finger.
PostPosted: Wed Jan 23, 2019 12:59 am
Thanks Matt, now I understand. :wink:
