Arkansasdawg wrote:
Looking at fishing kayaks for my first kayak. I like to trout fish on local river but does have exposed rocks and shallow shoals. It appears that the rudder on the outback does not fully retract. Do you see that as a problem in shallow water?
I fish lots of shallow water at the edge of lakes, over rocks and submerged trees, plus over ocean jetty rocks, and have never had any issues with the drop down rudders (PA12 and new Outback) or twist and stow rudders (Oasis and i11s). The drop down are better because they are spring loaded and just bump up out of the way, then back down. The twist and stow need to be re-locked into the down position if they hit something hard enough.
Getting good at feathering the Mirage Drive fins is important, and the new Outback has a design change that moves the drive up a bit which protects it better and allows the fins to push tight against the hull.
cheers, roger
