It is currently Sat Nov 28, 2020 3:30 pm
PostPosted: Fri Oct 30, 2020 3:12 am
Hi there,
I bought a used FX One and I wanna change some parts, which are attached with pop rivets.
I don't find anywhere what rivets to be used for which part, can anybody help me? I'm especially interested to change the following parts:
- Spi Pole Attachment
- Fore Stay Attachment on the Mast
- Mast Top where the Sail Hook goes in
- Goose Neck
If you know the HC item numbers and amount of rivets needed, that would make my day!
Thank you!
Matthias
PostPosted: Fri Oct 30, 2020 9:35 am
I expected to find it here:
https://media.hobie.com/digital_assets/ ... 202007.pdf
But I did not, so I checked the H18 assembly manual. While the hardware is different I believe the same rivets (8010181) and rivet sleeves (99210050) are used. The halyard hook may take a longer rivet (8011231)
https://media.hobie.com/digital_assets/ ... 2017-6.pdf
You will need one for each hole :)
PostPosted: Tue Nov 03, 2020 12:08 pm
Thank you!
And yes, one per hole. :-P
