It is currently Sat Jun 24, 2017 6:31 pm
PostPosted: Tue Jan 11, 2005 6:26 pm
Has anyone don this?
& dose any one have the rigging lengths for this setup?
thanks
Chuck
 Post subject: Will it work / fit?
PostPosted: Wed Jan 12, 2005 9:57 am
Will it work / fit?
The lower forestay on the 17 Sport is just inches longer than the 18, so the luff length should be fine. The 17 is virtually a Hobie 18 deck, so the dimensions to the jib clew should be similar. You would attach jib sheet blocks as on the 18 or nearly so. On the tramp track area 1/3 way back from the forward cross bar.
Anybody actually do this?
PostPosted: Thu Feb 03, 2005 5:50 pm
Thanks Matt
I'll let you know how it go's
Chuck
 Post subject: I dont know
PostPosted: Fri Feb 04, 2005 1:46 pm
I'm not too optimistic. My dad is a sailmaker and he has always told me that it takes VERY LITTLE to ruin a foil. There will either be a fold (bad) in the sail or you'll have cut it (worse). I mean did you know that in most boats the front third of the main is useless. The mast doesn't let the wind attach and create lift. You could end up going faster w/o a jib than with it. The foil (or lack thereof), wont let the wind hit the leeward side of the sail, the whole idea of the jib.
"I'm just tryin' to keep everything in balance, Woodrow. You do more work than you got to, so it's my obligation to do less." Augustus 'Gus' McCrae
 Post subject: hobie 17 jib
PostPosted: Fri Apr 01, 2005 2:05 am
I'm working with a sailmaker/rigger to get a jib and hardware kit together at the moment. Our feeling is to go for a self tacking jib in order to speed up tacks as well as reduce 'operator involvement' of course to do this we have had to put a pole from the mast step to the new front bridle, so guess what we made it slightly longer and added a spinnaker also!!! I can report that the spinnaker makes a massive difference downwind (as you might expect)... so much for reducing operator involvement!!
when all is sorted, I will make available pictures and dimensions. :twisted:
 Post subject: Fitting 18 Jib to 17
PostPosted: Sun Apr 10, 2005 5:34 pm
Chuck, I got a "Super Jib Kit" from Murrays, and I am told it is an 18 jib. Check it out at Murrays. If you have any questions on how to do it run a search at www.catsailor.com's new forum. I think I explained the whole procedure there. Otherwise let me know if you have questions. I have done this on two H17's. Brian 8)
 Post subject: Big Jib
PostPosted: Tue Apr 26, 2005 6:34 am
As long as you can control the slot opening between the Jib and Main, you will see some performance gain. That slot is ultra important. You can easily choke the main. Barberhaulers!
Uni-rigs will almost always point higher. Broad reaches will be where you pick up the majority of your new found performance.
 Post subject: Re: hobie 17 jib
PostPosted: Tue Dec 05, 2006 12:00 pm
Hi!
Have you done this? What kind of spinaker did you use on your HC17? Do you have any pictures?
BR Hans
Sails a 1987 HC 17 with new main and jib from 2006
