Rudder Cam wear http://www.hobie.com/forums/viewtopic.php?f=15&t=15112 |
Author: | fastcat [ Mon Sep 21, 2009 4:27 pm ] |
Post subject: | Rudder Cam wear |
I seem to be going through rudder cams faster than what would seem normal. I sail about 30 - 40 days/season in medium breeze to windy conditions and have to replace my rudder cams at least every other season. The top of the cams get streached out allowing the rudders to pop up when in chop and/or adding a significant amount of weather helm when pointing. |
Author: | mmiller [ Tue Sep 22, 2009 9:20 am ] |
Post subject: | Re: Rudder Cam wear |
Grease, Lubrication between the cam and plunger. If dry and too tight, you damage the cam. |
Author: | fastcat [ Tue Sep 22, 2009 11:53 am ] |
Matt, would you suggest lithium grease, marine trailer grease or ?????. Thanks |
Author: | mmiller [ Tue Sep 22, 2009 2:11 pm ] |
Either... even suntan oil, chapstick. What ever you have at the beach when in need! |
Author: | fastcat [ Tue Sep 22, 2009 2:32 pm ] |
Thanks |
Author: | h17cat [ Mon Oct 05, 2009 9:38 pm ] |
Another approach some of use is to cut off the top end of the cam, about 3/8 inches. With this modification you can lock down the rudder with the cam in either position. This is helpful when racing. Caleb Tarleton |
Author: | J_Eaton [ Tue Oct 06, 2009 5:48 am ] |
h17cat wrote: Another approach some of use is to cut off the top end of the cam, about 3/8 inches. With this modification you can lock down the rudder with the cam in either position. This is helpful when racing. ??? Won't they tend to unlock in heavy air?
Caleb Tarleton |
Author: | srm [ Tue Oct 06, 2009 7:32 am ] |
J_Eaton wrote: h17cat wrote: Another approach some of use is to cut off the top end of the cam, about 3/8 inches. With this modification you can lock down the rudder with the cam in either position. This is helpful when racing. ??? Won't they tend to unlock in heavy air?Caleb Tarleton Where I've seen this done, a bungee cord is used to hold the upper casting/tiller arm down. As long as the arm is held down, the kick-up mechanism will function normally. Personally, I think if you just do some periodic maintenance on the system, you should be fine. Small amount of grease on the plunger surface, make sure the slider plate is properly positioned, and replace the cams every couple years. sm |
Author: | h17cat [ Tue Oct 06, 2009 9:40 am ] |
I picked up the idea of trimming the rudder cams at the H-17 NA's in 1995. Have been racing with this change in all conditions since then. Never have had a rudder kick up. I did not add the shock cord. Caleb |
