It is currently Fri Nov 24, 2017 8:00 am
 Post subject: H17 rudders holes
PostPosted: Thu Feb 17, 2005 11:20 am
I purchased a couple of used rudders (excellent condition) which were used on a H16. I can see where the H17 holes should be but want to be as percise a possible.
Is there a template I can use do ensure the holes are exactly where they should be? What size should the holes be?
Joe
PostPosted: Thu Feb 17, 2005 11:31 am
Go to the top of this screen click on support. Go to sailboats click look for rudders there you have it :D
I would sugest you read in open fourm the thread on rudders. Its agood idea if you know of anyone with a good template on there boat to use them just a thought good luck :lol:
Todd
 Post subject: rudder template
PostPosted: Mon Feb 21, 2005 11:30 am
Todd,
Thank you for the information. I downloaded both versions of the template but the deminsions don't match. The length should be 9 3/8" and width 6 3/8" but the printed version is not even 9" wide.
I printed both in portrait and landscape with no change.
How do you get the correct size template?
Joe
 Post subject: Template size
PostPosted: Mon Feb 21, 2005 11:37 am
Template size...
The size it prints will depend on your system. The scale is there on the template so you can reduce or enlarge to get it right. A lot of printer settings (properties) allow for scaling. You can also use a photo copies to scale.
cron
