It is currently Sat Jul 22, 2017 8:54 am
 Post subject: Mast Rotation
PostPosted: Sat Jun 21, 2003 10:43 am
Hi,
I'm trying to figure out the best way to control Mast Rotation on a Hobie 17.
Can someone who has a successful Mast Rotation control, please explain the setup for me please.
I have a full boom.
TIA
Nige
 Post subject: Rotation Control
PostPosted: Mon Jul 14, 2003 7:17 pm
Most (all?) the racers use the stock system for controlling rotation, although the style of cleat on the boom can vary. I use an aluminum clam cleat, which can be tough to uncleat after an upwind leg in heavy air.
I put a mark on the line to give me a reference point so that I can set the rotation consistently. A good starting point is to have the rotator arm pointing at the shroud when fully sheeted in.
PostPosted: Tue May 04, 2004 10:04 am
You have probably seen the positive mast rotation set up with the shock cord attached to the hull tips and the pully on a rope attached around the mast and to the end of the rotator. It works well.
PostPosted: Thu Nov 03, 2005 8:17 pm
Buy a mast rotator arm for a boomlees and a Hobie 20 system from www.murrays.com. Works GREAT for me. This will control over rotaion for down wind. Then I have a line running from the arm to a (don't know the exact name of cleat, line runs thru it) to control mast roation going to weather. Hope this will help.
Doug
 Post subject: Mast Roatation
PostPosted: Sat Dec 17, 2005 12:06 am
Nigel:
This is what I did:
I bought a mast rotator arm for a boomess from Murrays that is Like a V going out from the mast and straight across the back. I use the system for a Hobie 20 with two snaps rings, three pieces of line and shock cord. Tie the line across the bridle conncetors at front of beams. Then with line tied to holes in mast rotator I clip one end of shock cord to rings and loop it around front line and back to rings. This pulls mast forward for downwind to 110 degrees. For mast rotation I have a small pulley system with cleat that attches one end to boomand other to mast rotator. This sets mast rotation. Hope this make sense? If not call me. :D 8)
Doug Snell
281-326-2702
dsnell4@houston.rr.com
PostPosted: Sat Mar 04, 2006 12:26 pm
I checked Murrays; didn't find anything special for boomless. How looks the boomless mast rotation system? :roll:
 Post subject: rotation system
PostPosted: Sat Mar 04, 2006 2:01 pm
Frank:
Order part 24-3042 from Murray's. That is the arm. You will have to get the parts for the shock cords system and pulley system yourself as they don't make the bungee system kit anymore. If you are confused, call me and I will try to explain it to you. Real easy system that works great.
Doug Snell
281-326-2702
