It is currently Sun Nov 19, 2017 8:02 am
PostPosted: Mon Jul 25, 2005 11:49 pm
I own a 1986 H17. Over the weekend I launched, forgetting to plug the hulls. I parked the car and returned, heard a hissing sound which finally triggered my memory. I pulled the boat out of the water and the starboard hull fully drained in about 30 seconds, but the port hull took about four minutes to drain a large amount of water, during which I heard a loud flow of air coming from the hull at the casting pocket for the front cross bar.
Am I looking at a known problem with a straight-forward DIY repair? Or is this something unusual or serious? If you know how to remedy this, I would really appreciate your comments and advice. I would also appreciate advice on leak detection and other problem spots to look out for.
Thanks,
Dan
 Post subject: Hobie 17 "leak"
PostPosted: Tue Jul 26, 2005 10:26 am
Dan, the 1986 Hobie 17 has vent holes under the front cross bar. This is to prevent pressure build up during temperature changes or while traveling over altitude changes. See other posts for leak checks. Do not plug the vent holes.
Caleb Tarleton, Seattle
PostPosted: Tue Jul 26, 2005 1:55 pm
Hi Caleb,
Thanks for the reply. That is excellent news and also answers questions I had about harmful hull pressure changes due to temperature and altitude changes.
By comparison, my starboard hull took on so little water. I can only guess that the drain plug was semi inserted during launch. If not, then perhaps I have a plugged starboard vent. I'll check that out.
Thanks,
Dan
PostPosted: Sun Mar 19, 2006 2:48 am
The vents are needed not just for temp and altitude changes, but for the realtime flexing of the hulls when underway, especially in rough water.
