It is currently Mon Jan 22, 2018 5:11 pm
 Post subject: Repairing Hull Sockets
PostPosted: Thu Jul 03, 2003 6:18 pm
My Hobie 17 has cracks in the hulll sockets that recieve the wing tubes. What's the best way to fix them?
PostPosted: Fri Jul 04, 2003 7:07 am
Do you have deck ports? If not, installing some near the holes will give you enough room to seal the tubes from the inside.
PostPosted: Sat Jul 05, 2003 8:20 am
My boat doesn't have the inspection ports. What size ports should I install?
PostPosted: Sun Jul 06, 2003 7:50 pm
I have 5" ports in mine. You could probably get away with 6" ports, but you don't want to go any smaller or else you wont have enough space to work through.
PostPosted: Mon Jul 07, 2003 3:08 am
Thanks, I'll see if I can get a pair. Only the stern sockets seem to be damaged.
