It is currently Tue Nov 21, 2017 9:26 am
 Post subject: H17 Flotation
PostPosted: Mon Apr 12, 2010 10:35 pm
Hi, all i'm in the process of putting four deck ports on my H17 holes are cut, but in removing someoff the styrofoam in the rear so i can repair the wing tubes the styrofoam is wet on the bottom as in waterlogged somewhat.Since they are waterlogged which creates xtra weight not much im sure but enough, could i remove all ofthe styrofoam would it be ok without. pros/cons. I had a H16 and when i cut the hulls up there was no foam in those is there certain Cats that have added floatation and some that dont.Thanks for your help ahead of time.Brad
The Waters always there,just wanting some good wind.
 Post subject: Re: H17 Flotation
PostPosted: Tue Apr 13, 2010 3:59 am
All the boats have internal flotation blocks as a safety measure. I'm not sure what happened to the ones in your 16 - did it have deck ports? Someone could have removed them.
I wouldn't remove the flotation blocks. Yes, the boat would be lighter, but in the event you are holed, the hull would sink and turn an unfortunate incident into a recovery/rescue operation.
Anyway, since you've cut ports in, you can leave the covers off to let the foam dry out. On my old 17, I took an old kitchen exhaust fan and mounted it in a piece of round duct, then placed it over one of the ports to get the air moving inside the hull. That dried it out really quick.
If the block is in the way, you can usually slide it out of the way to get better access to the wing tube.
