It is currently Tue Jan 23, 2018 9:27 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: Centerboard Handles
PostPosted: Mon Sep 19, 2011 11:46 am
It's all or nothing. The boards are so small and inefficient that using a halfway setting really isn't necessary. Plus, for racing we're doing windward/leeward courses, so there is no beam reaching.
PostPosted: Mon Sep 19, 2011 12:21 pm
I thought most race courses had at least 3 marks with 2 of them (A&B) set up for a reach. :?:
PostPosted: Mon Sep 19, 2011 12:46 pm
All or nothing. Well, not actually nothing. As srm has explained before, it's really hard to get the knot on the line in the correct position to have the board completely flush with the bottom of the hull - and it's hard to pull it up that far and get the knot into the "cleat".
There's actually less drag by having the board out an inch or so - it fills the slot in the hull more completely.
PostPosted: Mon Sep 19, 2011 2:45 pm
Not for about 15 years in most areas. It's three marks, but two of those marks compose the leeward gate which is only about 8 or 10 boat lengths apart. B-mark is a distant memory.
PostPosted: Mon Sep 19, 2011 3:08 pm
There have been some calls to "bring back the reaches," especially when the breeze is up if only for the carnage to ensue. As a race officer, I'm willing to give them the reaches if I've got the conditions and resources (mark boats and marks) to pull it off correctly.
The 17SE really doesn't like to reach and was the first class to go to exclusively windward/leeward courses with leeward gates at the 1996 Continentals.
PostPosted: Tue Sep 20, 2011 8:42 am
Though not a racer per-say (only been in 3 regattas in 28 years), I think it's a shame not to have reaches. That's where the fun is, both speed and power. There are times when it is blowing around 15-20 knots that I more resemble a windsurfer, doing one screaming reach after another. There isn't more fun than sitting on the back corner of the windward wing with the boat dialed-in, galloping through and surfing the waves on one hull - sweet.
I gather the SE isn't a reacher because the lack of a jibe, because the Sport is a reaching fool, as is the skipper. :wink: :lol:
PostPosted: Tue Sep 20, 2011 8:20 pm
Quarath wrote:
I am curious as to what others have used for alternative handle options
from Bruce Fields (aka Wrinklie)
get a piece of surgical tubing (or clear tubing from the plumbing dept.), with slightly larger I.D. than your lines' O.D...2' will be plenty.
Tie the bitter end back off to the line about an inch above your down position ball.
Start long and shorten until the length suits your taste.
Similar to having a J&H handle on the end of your line (and I think I've seen that setup somewhere)
Sheet In...Max Out
www.fleet297.org
