It is currently Sun Jun 25, 2017 4:16 am
PostPosted: Tue Aug 28, 2012 2:53 pm
Let me start off by apologizing if this is a stupid question.
Does anyone know the dimensions of the jibs on H14, 16, or 18 compared to the hobie 17? I am asking because I am wondering if I must buy a hobie 17 conversion kit or if I can get away by using something else, for instance a hobie 14 jib roller furler kit.
I understand that the conversion kit would also give me a boomlet, but right now having a jib is a higher priority. Any suggestions?
Thanks!
PostPosted: Tue Aug 28, 2012 5:40 pm
A critical component of the 17 kit is the bow compression spreader, which allows the bridle to be lowered to a reasonable height without breaking the bows off. You cannot install a jib without this component. (Well, you can, but you'd break your boat.)
You can see it between the roller-furling drum and the bows in the photo below:
PostPosted: Thu Aug 30, 2012 1:29 pm
Murray's Marine also sold a jib kit fo the H17. I just happen to have one that I don't use. Includes the spreader, furler, forstay, jib (reacher), blocks and sheet. if you are interested skilehrsx4@sbcglobal.net for details.
