It is currently Thu Mar 23, 2017 7:29 am
PostPosted: Thu Nov 29, 2012 5:53 pm
My hulls are super chalky and the pin striping is faded.
I want to give her a spruce up.
What is the path of least resistance to a fresh coat?
What type of paint?
What is the process of repainting her?
Many thanks!
PostPosted: Fri Nov 30, 2012 2:42 pm
I re-painted my boat against advice to approach that job very cautiously. That was good advice.
If it is just chalky try polishing it out. Get advice from someone who knows the best treatment to use and try it. Re-paint is a serious PIA to do it properly.
Pinstripes? Again maybe you can polish those off and apply new tape stripes to make it look right again.
PostPosted: Mon Apr 22, 2013 8:41 am
use- petit or interlux paints.. they give free advice . follow there professional advice. Tom
PostPosted: Mon Apr 22, 2013 9:15 am
Strip the stripes. Wet sand the hulls. Buff them out. Replace the stripes (optional). Wax. You'll want a rotary buffer with a couple of different pads and an orbital polisher for the wax. You can do it in a day, but you'll be really tired when you're done.
adell50 wrote:
What type of paint?
None. Don't do it. Doing it right is more work. Doing it half-assed looks . . . half-assed.
If you really want to go there, surface prep is the key to a great looking paint job. The more time you spend there, the better it will look. However, any paint job is going to chip, flake and get worn off the bottoms. It fills up the pattern in the non-skid. Paint isn't as thick as gel coat and isn't as flexible.
The best-looking paints are also the most noxious. You need supplied air if you're going to spray them. Spray booth helps, too.
Seriously, you can clean the hulls up in a day of pretty unskilled labor, with minimal investment in tools and consumables (less than $200, tops), or you can spend a lot on equipment (spray gun, compressor) and really expensive paint (some of the 2 part polyurethanes cost $70/quart) and still have an inferior job.
