It is currently Tue Mar 28, 2017 11:14 am
 Post subject: Fx1 two Up
PostPosted: Fri May 30, 2008 8:07 am
Hi,
I usually race my fx1 one up but am racing an event two up any got any tips for two up that might differ from one up racing
PostPosted: Sat May 31, 2008 5:40 am
Get a jib? Keep your crew doing as many tasks as possible. Use the extra weight to your advantage when ever you can. (Low side of the boat in light air, that kind of thing)
PostPosted: Thu Jun 05, 2008 8:22 am
was wondering about mast rake, diamond wire tension
PostPosted: Thu Jun 05, 2008 11:09 am
Use the added crew weight to your advantage and stay as far forward as the conditions permit. Try to stay together when going to weather to prevent the see-saw action inherent with weighting on the ends. Power up with less mast rake and less diamond wire tension and adjust for the conditions. Avoid traveling out when close hauled unless absolutely necessary.
