It is currently Wed Mar 22, 2017 10:32 pm
 Post subject: Shroud tension
PostPosted: Fri Jul 16, 2004 12:52 pm
How taut should my shrouds be? Depending on the wind they get a few inches of slack. :?
Don in NC
PostPosted: Thu Jul 22, 2004 9:17 am
I always sailed with a fairly loose rig like you describe. If the tension is too great, the mast will not rotate as easily.
You might want to have more tension in higher winds. Helps keep the mast attached to the boat. :wink:
PostPosted: Thu Jul 22, 2004 11:45 am
Thanks, that's one less thing to worry about.
Don in NC
