It is currently Thu Mar 23, 2017 11:03 pm
 Post subject: Advice
PostPosted: Sun Jan 10, 2010 2:10 am
when i lift one hull it takes a while for the other one to come up...
is there anyway to fix this?
My H14t
currently being sanded back and repainted..
 Post subject: Re: Advice
PostPosted: Sun Jan 10, 2010 6:26 am
In increasing levels of permanence:
1) shim the pylons/casings with strips of brass or aluminum. Take the boat apart, bend the strips in the shape of an upside down "J" and hang the strips on the edge of the pylon, then reassemble.
2) Shim / glue - in addition to the above, remove the castings from the crossbars, epoxy them back on and re-rivet them.
3) Glue the boat together in addition to gluing the castings to the sidebars, epoxy the castings to the pylons.
For #3, you need to have the boat on a level surface and make sure the boat is square while the glue sets.
In all cases, you need a really tight trampoline. The easiest way to do that is to use your mainsheet system to pull the sidebars inward, lace the trampoline and pull it tight, then let the mainsheet off.
PostPosted: Mon Jan 11, 2010 2:49 am
do i need to do this??
or will my boat be ok?
My H14t
PostPosted: Mon Jan 11, 2010 5:30 am
You don't need to do any of that. The boat is fine. However, it will be much more responsive on the water.
