It is currently Thu Jun 22, 2017 8:39 pm
PostPosted: Mon Apr 11, 2011 5:26 pm
I have the furler system and was curious how other sailers step the mast
with the sail wrapped around the forestay on a windy day when I step the mast it sometimes becomes unfurled before I can connect the forestay to the furler
what I have come up with is to put a jib snorkel over the jib before stepping the mast then removing it after I get everything set so I can unfurl the jib, attach the jib sheets to the jib then pull the string on the furler to refurl the jib so I can put the boat in the water and raise the main.
There has to be an easier way, I doubt everyone sailing a 14T has a cover for the jib, especially if they trailer it and are removing the sails, so I'm asking how everyone else does it
Thanks in advance for your responses
PostPosted: Mon Apr 11, 2011 5:34 pm
Put a bungie cord in the clew around the jib and back in the clew. On my friends Getaway, there is a loop on the sail a few inches fom the clew that the snap hook on the clew can snap in.
Marc...
PostPosted: Thu Apr 14, 2011 5:39 pm
The jib I bought arrived tied together using bits of sail cloth as a ribbon. I just use one of those ribbons and it holds it together nicely. A piece of string would do it too.
PostPosted: Thu Apr 14, 2011 7:34 pm
I use a bungie clew to clew and it works great to keep it all together till I'm all set up to launch.
'95 H16 sail #101148
'89 H18 SX/ sail #1053 w/ Yellow hulls
