mast question http://www.hobie.com/forums/viewtopic.php?f=17&t=35471 |
Author: | lafouchat [ Tue May 10, 2011 12:25 pm ] |
Post subject: | mast question |
hi again, I have a 2 part h14 mast, nthing comptip.... at the connection i have the next thing: what could i do with this? I can hoist the sail correctly, but the upper part is a little bit baggy.... |
Author: | mmiller [ Tue May 10, 2011 12:34 pm ] |
Post subject: | Re: mast question |
That is a Hobie Europe mast. Upper part (sail) is baggy? Loose connection you think and the mast tips back at this joint? You might consider epoxy and rivets for the joint to hold it straighter. |
Author: | lafouchat [ Tue May 10, 2011 1:09 pm ] |
the upper part is seat a little bit different...without the main, it is a little bit turning to front....when hoisted the sail, and the mast rotated it is turn into windward and a little backward.... I will try to fix it with epoxy and rivets. Thanx!!! |
