It is currently Sat Jun 15, 2019 8:34 pm
PostPosted: Sat Aug 23, 2003 8:08 am
Little by little, I am finishing the conversion of my 81 hobie 14 to a turbo. Wolf's Marine in MI. ordered the new chain plates for me but the "8010181 RIVET 6-4 PN HD MONEL" are on backorder indefinetly. Will try to find another source. I understand the 3/16" dia, 4/16" grip Monel rivet part. But what is the "PN HD" spec ?
What size rivets are used for the Dolphin Striker post - to - front beam ?
They are not listed in the rivet list.
Rivet Diameter in .........Maximum Grip Length
32nds of an Inch .........in 16ths of an Inch
(-6 = 6/32 = 3/16) .......(-04 = 4/16 = 1/4)
Jon :?
PostPosted: Sat Aug 23, 2003 10:41 am
Authorized Hobie Dealer
I have 12 left in stock, as long as they are marked correctly. Give me a call and we will figure it out.
Brad Stephens
www.sunjammers.com
brad@sunjammers.com
850-235-2281
Authorized Hobie/Vanguard Dealer
Panama City Beach, FL
PostPosted: Sat Aug 23, 2003 3:05 pm
Jon- The pnhd spec is for a pan head rivet ( head kind of looks like an upside down pan ) as opposed to a countersunk or flat- head rivet. For the dolphin striker post- you could measure the holes in the post and see if they're countersunk or flush,and guess the depth- I think 1/4 inch grip range would probably work. I have an '82 but it has the rigid dolphinstriker. The turbo conversion's worth the trouble! 14's forever!
Hope this helps,
Dave
PostPosted: Sat Aug 23, 2003 6:31 pm
Turbofan
Thank you very much. I was trying to remember all the nomemclature that was used for the 'Cherry Max' rivets we used on the Navy Helicopters. I think pan heads were referred to as button heads, I even ordered rivet guns, but 13 years is a long time to remember for a jet engine mechanic working in the supply/tool room for a few months. (':oops:')
The dolphin striker has a slight reccession, so pan heads will work. I needed to know what grip range to use since the holes are different depths, (? 9/32" & 15/64" ?). I still need to clean the old silicon and corrosion off the striker. I guess the angle/position under the beam is just the best fit with no gaps ?
I can use the info for the chain plates & rivets, assume the same thickness in the front / side beams (? 11/64" ?) and make sure the grip range in there. Then find someone with an air rivet-gun or hydraulic hand gun. We never pulled 5 or 6s with a cheap hand gun. (':D')
update: My calculations determine the striker needing 2) 6-7 & 4) 6-8 rivets. (':D')
Jon
www.peerlessaerospace.com/pub/Productim ... RRYMAX.pdf
