It is currently Tue Mar 28, 2017 7:28 am
PostPosted: Wed Apr 04, 2012 6:15 pm
Hello All,
I am new to the forums and to Hobie's in general. :)
I have owned a monohull Laser 2 for several years and have been recently introduced to Hobies through a friend of mine who purchased a H14 (non-turbo).
I love my Laser, but struggle to sail it solo (I only weigh about 70kgs and find it tricky in high winds to keep the boat upright) and certainly dont have enough hands to use it to its full potential - with a Spinny.
I am 28 yrs old and I have a lot of experience with sailing. My father has two 50 foot yachts and I have had the benefit of learning from him for the entirety of my 28 yrs.
I've decided to follow my mates example and purchase a Hobie to make things easier for me. I am an Aussie and have found what I think is a H14T worth checking out. I was hoping I could get some advice and some Q's answered from some of you savvy Hobie owners before I inspect and commit to purchase. Below is the boat advertised on the Aussie Boatsales.com.au website:-
http://www.boatsales.com.au/boats-for-s ... R=12405266
The questions that I have are as follows:-
1. From the photos, the mainsail only appears to have 5 battens (unless I'm mistaken) from the pics on these forums of other user's boats, I understand that the traditional number is 6?
2. In some hobies, the battens are angled on the mainsail and in others, some are straight. Does this make any difference?
3. The jib seems strangely wrinkled... As it has no battens in it I am guessing that the jib is supposed to be self furling, but could not see any trace of a furler on this boat?
4. Also, the jib appears to actually be attached to the forestay (rather than on a separate halyard). Is this common? Without the halyard system, how would one take the jib down mid-trip without having to beach and dismantle?
5. I cant see any trapeze system on this boat and thought that the H14T came with a trap as standard. Perhaps this boat is actually a H14 which has been modified with a dolphin striker and a jib?
As I dont have a lot of experience with Hobies, I have read the helpful posts which indicate what to look for when buying a new hobie. I have a list of things to ask, but would certainly appreciate any comments or things that you experienced Hobie sailors might notice about this boat from these few photos.
Thank you very much in advance.
PostPosted: Thu Apr 05, 2012 9:18 am
Wecome to the forums and Hobies in general!
Whitelights wrote:
Hello All,
The original Hobie 14 sail had 5 battens. The design was changed in the early '80s so that the battens could be placed on the panel seams (easier to make), which resulted in the 6 batten main. The performance difference is marginal, with the 6 batten main being slightly faster.
No. I think what you are seeing is the difference between the 5-batten sail (where the battens are angled to the panels) and the 6-batten sail (where the battens are on the panel seams).
Unfortunately, the boat is no longer listed, so I can't look to see what's going on. On a 14T, the furler is pretty obvious at the jib tack.
On the OEM 14T jib, the luff wire is the forestay. There was no way to remove the jib without dropping the mast. There have been a few workarounds - a jib snorkel cover, hoisted by the main halyard to protect the jib from the weather (no modifications needed) or having a luff zipper sewn into the luff of the jib (separate forestay) that would allow you to rig a halyard system similar to either the 16 (cleat on the mast) or the 18 (inside the jib luff pocket w/ a cleat at the jib tack).
Could be. There were a number of "unofficial" turbo conversion kits before Hobie Cat formally introduced the Turbo in the early '80s. If the boat is older than ~1982 this is almost certainly the case.
No worries, mate!
cron
