It is currently Sat Jul 29, 2017 4:45 am
 Post subject: Jib Fluttering...
PostPosted: Tue Sep 11, 2012 4:12 pm
Hi! I just got back from sailing my 14 Turbo! Great afternoon!
II'm trying to figure out why the job flutters so much? I have the jib as low as it can go on the roller furler, and I have the mast raked back quite a lot.
It's the original sail from 1983, so maybe it's just blown out?
Any thoughts?
Thanks! :D
2011 H16... Have a Hobie Day!
1983 H14 Turbo...
 Post subject: Re: Jib Fluttering...
PostPosted: Tue Sep 11, 2012 7:36 pm
That's more than likely your problem, but the basic problem is that the leech doesn't have enough tension. The only way to change that is to change the angle of the jib sheet so it pulls more down than back than it does now.
But I doubt if there's enough adjustment to take care of a 30 year old sail's blown out leech.
PostPosted: Wed Sep 12, 2012 4:59 am
Thanks Matt!
I'll look at replacing it in the coming months... :)
1983 H14 Turbo...
PostPosted: Thu Jan 31, 2013 5:45 am
Often a sail maker can recut an old jib and that might fix the fluttering
PostPosted: Thu May 16, 2013 12:25 pm
If you go this route, have them add a leech line. This can be used to 'calm' the leech with an adjustable tension.
PostPosted: Mon Nov 04, 2013 11:41 am
My 14 Jib is old and was pretty ripped up, but i took it to an upholstery shop and had the holes covered ($40), and the leech line replaced and its sleeve re-sewn. That leech line really does a lot of work in decent winds, i found this out because i sailed on it while it was still messed up.
So depending on the condition of the sail, mast rake, how you sail and etc., you might be looking at just having it repaired a bit. Otherwise, I would hate to have to try and find another jib, they can get pricey...
