Separating trampoline frame and hulls http://www.hobie.com/forums/viewtopic.php?f=17&t=47567 |
Author: | copp-y-cat [ Mon May 13, 2013 9:14 am ] |
Post subject: | Separating trampoline frame and hulls |
Advice wanted again please on separating the tramp frame from the hulls. The bolts came out easily but cannot ease the frame off the uprights. I assume the main reason is aluminium oxide between the two mouldings but 1. Do I need to free off the dolphin strimer crossbar before trying to separate and 2. Has any one tried putting a 10 inch wide plank on the hulls and using a small jack to provide more force. I will try and sock the joint with WD40 before doing that. Thanks David |
Author: | sunvista [ Tue May 14, 2013 7:00 am ] |
Post subject: | Re: Separating trampoline frame and hulls |
Make sure one of the previous owners didn't epoxy the frame onto the pylons. A lot of sailors do this to improve rigidity. I wouldn't recommend the jack. The fiberglass might give before a severely corroded or epoxied joint. Have you tried heat? |
Author: | mmiller [ Tue May 14, 2013 3:33 pm ] |
Heavy sand filled "Dead Blow" or Rubber mallet. Hard swings in an upwards direction to impact each corner casting one at a time. Fore and aft for each hull in balance. It takes SIGNIFICANT blows typically... and many of them. |
Author: | drummer63 [ Tue May 14, 2013 3:58 pm ] |
Second Matt's comment - my 16 was a bear and it is hard to angel the mallet without hitting the hulls etc on the way up so i had a piece of 2x4 wrapped in cloth that i put against the casing and hammered the bottom of the plank - works like a charm |
