It is currently Fri Apr 19, 2024 5:42 pm
 Post subject: jib halyard
PostPosted: Fri Aug 02, 2013 7:23 am
Could someone give me an idea about how place a jib halyard in my H14T. I dont want to remove the mast each time. Thanks.
 Post subject: Re: jib halyard
PostPosted: Fri Aug 02, 2013 9:50 am
It would be a lot of work. You would basically have to create a system that operates like the H18 system. This would include having the jib modified to install a zipper along the luff sleeve, a cleat added to the jib to set the jib halyard tension, and the forestay would need to be modified to add a halyard sheave. This would be pretty expensive.
You would be a lot better off just buying a "snorkel" jib cover. They are hoisted using the main halyard and are installed over the jib when it's furled.
PostPosted: Thu Aug 08, 2013 6:32 am
Thanks. I will try.
PostPosted: Fri Jul 03, 2015 11:52 am
This is what I did to my H14:
I took the sidestays from a H16 and cut about 50cm off of them and then recrimped them.
They go from each bow up to a H16 halyard block.
The jib can still be furled without the forestay getting twisted in the jib.
cron
