It is currently Fri Feb 21, 2020 12:04 pm
PostPosted: Mon Oct 07, 2019 9:14 pm
Hello, took my mirage sport out this past weekend and noticed a decent amount of water in the hull. I haven't ran Amy pressure tests to check if there is a hole in the hull but I did give it a quick visual check with a flashlight in the hull. I couldn't find any hulls but noticed that the plastic gaskets where the rudder lines run through are cracked/broken. I was wondering if water would be able to enter through thoses gaskets. If so, where can I get replacements and/or what are alternatives to getting those holes fixed?Image
https://photos.app.goo.gl/eyqmvfh6N3gSUXhV6
PostPosted: Tue Oct 08, 2019 1:07 pm
There is an o-ring that is inside the tube that should seal it. You can replace the line in the tube as an assembly:
80025001 LINE CONTROL ASSY - (1) LINE
PostPosted: Tue Oct 15, 2019 1:32 pm
So I ended up running the water test(I filled the hull with soapy water and lifted one end and then the other, looking for spots where water was leaking. Luckily, the hull seems to be ok, no holes. My suspicion was correct, the water is going in through the rudder up/down line entry holes. Water was also moving through where the Up/Down knobs/pull levers live, I don't know if that is normal. Looks like I'll need the above replacement?
