It is currently Tue Mar 19, 2024 12:52 am
PostPosted: Wed Jan 19, 2022 5:39 pm
Hello,
The front fin on my MD360 is not going all the way back into place properly after kicking up. What can I do to fix this problem?
PostPosted: Thu Jan 20, 2022 10:00 am
brettg2309 wrote:
Hello,
Contact your dealer - assuming that the nose cone is worn - if they kick up a lot in your area running shallows and impacting obstacles a lot - or the water has a lot of grit, the latch will wear - it's a very inexpensive part to replace - part number is 80151060 $9.99 each
Jacques Bernier
http://www.hobie.com/
PostPosted: Fri Jan 21, 2022 4:14 pm
Thanks very much for your reply. I will buy one and see if that fixes the problem and let you know.
