It is currently Mon Jan 22, 2018 9:57 am
PostPosted: Tue Sep 15, 2009 3:08 pm
Title says it all...ive searched and searched- where do i get one?!?
1981 Hobie 16
1982 Hobie 14 turbo (sold)
1996 SeaDoo GTI
1999 Hunter 340
PostPosted: Tue Sep 15, 2009 6:31 pm
Go to the drug store and buy a large earwax removal syringe or a catheter syringe. I've even used kitchen turkey baster. Just remember, the larger the syringe, the faster the epoxy is going to start to catylise or kick. Small is better. The West System syringes are best. They also sell re-usable caulk gun tubes.
http://www.westsystem.com/ss/mixing-application
PostPosted: Tue Sep 15, 2009 6:37 pm
This took like 2 minutes w/Google:
http://www.medcareproducts.com/prodinfo.asp?number=SB100
PostPosted: Fri Sep 18, 2009 2:09 pm
I got mine from a feed store. Most any store that sells horse or other large animal feed carries syringes.
PostPosted: Sat Sep 19, 2009 9:41 am
I just drill the hole same size as the Git Rot top of squeeze bottle and there you go I cover holes with Marine Tex
Drill your holes several days befory you epoxy
leave hull in sun but protect from rain. Epoxy works better if it does not have to fight moisture in the foam layer
The last boat I did had a lot of moisture the Git Rot took a long time to set but after a few days the hull was like new
I put my git rot in the cooler with ice before using it gives me much more time before it sets up
PostPosted: Tue Oct 27, 2009 5:08 am
West Marine has empty caulk canisters that will fit a standard caulk gun. Simply remove the end plug of the canister, fill with expoxy, load in the gun and squeeze the trigger. It forces the epoxy in very nicely plus you don't have to stop and refill that often since is holds a large capacity. Plus, after the epoxy hardens, simply sqeeze the side of the canister and the epoxy breaks away leaving a nice clean canister for re-use.
Eric Weller
2006 F18 Capricorn
1980 H16
Keep the pointy side up!
PostPosted: Tue Oct 27, 2009 3:40 pm
How Large are you looking for? I have used the type that are used in woodworking and they worked fine .
http://www.woodcraft.com/Product/202054 ... ieces.aspx
Mono slugs of various sizes and shapes
H 14 About 15 years ago
H 16 1982
Making Wake on A No Wake Lake!!!!!!
