It is currently Fri Jan 19, 2018 9:26 pm
PostPosted: Wed Nov 18, 2009 1:50 pm
How can you flatten a warped trampoline? There were a couple of items sitting on it for around 10yrs and they've left a few impressions in the vinyl.
Would a "not too hot" iron do the trick? Or maybe 20 min in a closes dryer?
It's white, and I've got to clean it as well. Any tips or products I should be aware of?
Thanks,
Andy
- Andy
=> Hobie Cat 14 <=
=> 1978 Chrysler 26' Herreschoff Designed Monohull <=
PostPosted: Wed Nov 18, 2009 2:36 pm
How about just putting it on the boat, lacing it really tight and set it in the sun for a while?
PostPosted: Thu Nov 19, 2009 6:47 am
Last night I cleaned them pretty thoroughly, but the top-side is still fairly stained.
Has anyone tried Mr Clean Magic Eraser for their trampoline? If so, how did it work?
- Andy
=> Hobie Cat 14 <=
PostPosted: Thu Nov 19, 2009 9:11 am
If its a white vinal tramp, i would think bleach should do the trick.
1992 Hobie Cat 18 #16943
PostPosted: Thu Nov 19, 2009 9:22 am
Man... I should have thought of that. I have to go through the laundry room to get to my boat...
- Andy
=> Hobie Cat 14 <=
PostPosted: Thu Nov 19, 2009 10:40 am
For stains, yes bleach can work. Also Ajax and a scrub brush will get rid of mildew and dirt.
For really harsh stains, sometimes the best fix is to just sail it... My boat has a yellow tramp. For a while, it was sitting outside in the backyard and a bunch of leaves got under the tarp and began to decompose leaving a large black stain on the tramp. I scrubbed the snot out of it which made it a little better, but still very ugly- mostly just turned the stain from black to brown. I eventually gave up and just decided to sail it. After a season of being bleached by the sun and being crawled on, all the ugliness is gone.
PostPosted: Thu Nov 19, 2009 11:02 am
Suhweeeet!
Just in case though, I picked up the Mr Clean "Magic Eraser"
Turns out that it's a box with 4 pre-soaped sponges. You get it wet, ring it out and use it. They're reusable until they don't work that well.
I've never used it, but on another motor boating forum I saw that quite a few people use it to get rid of stains on their vinyl boat seats. All of them said it worked fast and completely removed the stains.
I'll let you guys know how it works.
Andy
- Andy
=> Hobie Cat 14 <=
PostPosted: Thu Nov 19, 2009 11:15 am
Be careful using the bleach ,rinse throughly and reclean to remove any bleach.I use a conditioner on my white vinyl tramp to protect and rejuvenate the fabric.My boat is gunsmoke blue (a stars and stripes) and looks 5 years old instead of her real age of 20 because I have carefully cleaned,waxed and polish the gel coat and kept it cover.Be sure your tramp in off the boat when you use bleach...good luck Bill 404 21SE
Bill 404 21SE
PostPosted: Thu Nov 19, 2009 11:25 am
What type of conditioner do you use?
- Andy
=> Hobie Cat 14 <=
PostPosted: Fri Nov 20, 2009 9:49 am
I use Sparten Shine Plus as a conditioner during storage and wash it off before using my boat.A 32 oz. bottle last a long time and cost less than 20 dollar.It is slippery and can be trouble so wash it off before using the tramp and then retreat it to protect that vinyl inbetween sailing trips.This has keep my tramp in good shape for many years.You will find it at a janitorial supply company.Use it also on rubber door gaskets on your vehicles too,it has many uses. Good luck...Bill 404 21SE
Bill 404 21SE
PostPosted: Fri Nov 20, 2009 9:22 pm
I really like Spray 9 for just about all cleaning needs especially the tramp. You can pick it up a True Value, Ace Hardware and the like. Spray it on, let is sit for a minute or two, scrub and spray rinse. Awesome stuff.
Sail Like you Have a Pair
Bluish gray 73 - 83 H16
Super Nice Yellow 84 H18
PostPosted: Tue Nov 24, 2009 1:19 pm
OK, I looked for the spray 9 but didn't find it.
But, I found Star Brite "Mildew Stain Remover" and it works exactly as advertised.
You follow the same steps, spray it on, let it sit a while, scrub and rinse thoroughly.
I'm not even sure that I needed to scrub. I think that if I sprayed it on a little heavier I would have only needed to rinse it.
So far my cleaning methods for my 21SE are:
- Penetrol for all of the black metal (black mast, boom, crossbars, etc.), apply and wipe it clean as you can
- Soft Scrub for the hulls works great
- I have a clean trampoline thanks to Star Brite Mildew Stain Remover
- My aluminum Trailex trailer looks like NEW, I used aluminum rim cleaner on it (still looking for replacement slot bolts and the nuts, I'd like stainless)
- all rope: I read an article in Good Old Boat that said good rope responds well to a good wash in a clothes washing machine (my rope is so old I'm considering finding a collector)
- Andy
- Andy
=> Hobie Cat 14 <=
PostPosted: Tue Nov 24, 2009 3:26 pm
A few tips for you:
When using soft scrub make sure you was the boat afterwards because the soft scrub will leave a chalky look (I would was and wax it, using Star-Brite Teflon wax).
Also for new rope it isn't necessary to wash it in a washing machine. I've always just thrown in a bath tub over night with water and a little bit of fabric softener to loosen up the rope, so it's not so stiff.
PostPosted: Tue Nov 24, 2009 6:00 pm
- Andy
You can order replacement slot bolts and nuts directly from Trailex (www.trailex.com)
Stainless bolts are a bad idea. Electrolysis will eat away the aluminum.
PostPosted: Tue Nov 24, 2009 7:05 pm
I hadn't thought of that. I've dealt with that on my aluminum mast and stainless hardware on my other sailboat.
- Andy
=> Hobie Cat 14 <=
