It is currently Sat Dec 16, 2017 7:41 am
 Post subject: grommet kit
PostPosted: Thu Oct 21, 2010 7:28 pm
I bought a grommet kit from a popular online sail shop for $36 and then found the same thing from Harbor Freight for $2.99 !
Quality seems fine to me.
 Post subject: Re: grommet kit
PostPosted: Fri Oct 22, 2010 4:10 am
the only difference i would suspect would be the amount of brass on the cheaper ones. The mandrel is also made from aluminum vs steel in the more expensive kit. Will both of them work? yes. It is possible the cheaper ones will start to rust or leave stains and turn green quicker than the more expensive ones.
'73 hobie 16 restored 2011
'00 Seaswirl fishin boat
PostPosted: Fri Oct 22, 2010 4:47 am
Yes without a closer look I would be guessing the more expensive ones (grommets) are all brass or at least have a thicker coating where as the cheap ones are just thin brass coated. The mandrel also looks to be of better quality and will be less prone to bending or deformation from the hammering.
Both look like they will work though :wink: .
PostPosted: Fri Oct 22, 2010 9:08 am
I've found that most things from Harbor Freight will work, at least once.
I shop there quite a bit. You just never know what you'll find there!
What - Me Worry?
2006 Hobie Wave 7358
"Ish Kabibble"
