It is currently Sat Nov 18, 2017 1:35 am
 Post subject: Trapeze parts
PostPosted: Sun Apr 11, 2010 12:23 pm
I have had an H16 for two years, have never used a harness to hike out. I have the trapeze wires you see below:
But nothing else. What other accessories do I need to purchase? Since I've never owned a harness, please list literally everything I would need to attach those wires to me.
Broward County, FL
1984 Hobie 16, Olympic Edition (kept in NY)
 Post subject: Re: Trapeze parts
PostPosted: Mon Apr 12, 2010 9:31 am
1) Shackle to connect wires to mast tang.
2) Two lengths of line, approx 1/4" Dia x 3' long.
3) Two trapeze rings (piece that your trap hook engages into, "J&H" handles are the most popular on Hobies).
4) Two plastic rope stop/dogbones. These are used to set the trapeze height.
5) One piece of 1/4" bungee about 8 feet long.
This is the bare bones equipment needed for a single trapeze system. Double the quantity of items 2 thru 5 for a double trap system. You can also add a pulley to the end of each trap wire to make the system run more smoothly and you can add more elaborate "on the fly" height adjustment systems if desired.
PostPosted: Mon Apr 12, 2010 1:39 pm
What about a harness and some kind of connector?
And where do I use the parts you named?
Broward County, FL
PostPosted: Mon Apr 12, 2010 1:54 pm
p.s. I don't have a harness, or any such equipment. I've never had to use it. I've just held onto the trapeze wires or sat down and used the hiking straps. Do I need a different type of lifejacket?
Broward County, FL
PostPosted: Mon Apr 12, 2010 2:09 pm
Does anyone have a diagram, and instructions, on how to put all the parts together, and hook yourself up?
What kind of harness system should I buy?
What kind of trapeze hook?
Broward County, FL
PostPosted: Mon Apr 12, 2010 2:47 pm
The assembly manuals show the setup. These are in the model FAQ and our support area:
http://www.hobiecat.com/community/viewtopic.php?f=14&t=12697
You can see options for trapeze seats in the parts catalog:
http://www.hobiecat.com/sailing/accessories.html
