It is currently Tue Jun 27, 2017 9:41 am
PostPosted: Sat Mar 05, 2011 10:26 pm
OK, I've done a fair amount of searching, but I cannot find a difinitive step by step proceedure for repairing soft spots.
I understand the concept of drilling holes in the top layer, allowing for vent holes and injecting an adhesive.
My questions:
1) I've heard of folks using gorilla glue - true? I've used in other applications, sounds interesting since it expands and foams up.
2) If not the above, what kind of epoxy and I read that you thicken it up. In the RC hobby world we used "micro ballons" is this the same for this application?
3) Can I use regular medical syringes to inject the glue?
Many thanks!
Brian
PostPosted: Sun Mar 06, 2011 9:46 am
There is plenty of material on this topic since a lot of us are sailing some pretty old boats. Here are two articles that describe the procedure pretty well:
http://www.hobiecat.com/support/articles/archive/?src=http://2010.archive.hobiecat.com/support/tech/delam.html
http://www.thebeachcats.com/news/87/catamaran-sailboats-delamination-repair-instructions/
Here are some pictures of a repair on an H16 although this guy probably should have used epoxy in lieu of polyester resin. Not the place I'd be trying to save $20.
http://www.thebeachcats.com/pictures/?g2_itemId=64559
Here is a fairly recent thread on this subject with some good advice. This answers your question regarding the use of Gorilla Glue.
http://www.hobiecat.com/forums/viewtopic.php?f=14&t=31861
Here is one place to get syringes along with most everything else you might need.
http://www.jamestowndistributors.com/userportal/show_product.do?pid=2096&familyName=Epoxy+Syringes
Hope this helps. Good luck.
PostPosted: Sun Mar 06, 2011 9:48 pm
I think you'll find that most of the posts on this forum recommend using polyester resin rather than epoxy. Polyester resins and gels are what Hobie built these boats with and new polyester will adhere to your boat better. I'm no glass expert, I'm just passing along what I've discovered by researching these forums as I prepare for some repairs of my own.
Mark Van Doren
H14T Fantasia #47787
San Juan 28
PostPosted: Sun Mar 06, 2011 10:36 pm
First of all, thank you all for responding!
Question:
Humm, that is interesting. Is that really the overall concensus? It seems to be contrary to both of these articles:
http://www.ehow.com/about_5932927_polye ... resin.html
http://www.redrockstore.com/resin.htm
I just want to get it right the first time :-)
PostPosted: Mon Mar 07, 2011 5:36 am
General repairs, polyester is the way to go, unless you need extra strength and/or adhesion properties.
Fixing soft spots - epoxy. Git-Rot specifically, since it's slightly flexible after cures. That helps maintain the bond between the layers.
(Hi Brian - I'm probably the only one on the board that knows where the 555 comes from in your handle. Now that you've got a new boat, it's time to renew :))
http://www.hcanamembers.com
PostPosted: Mon Mar 07, 2011 5:19 pm
DAMN! I've been caught! :shock: :mrgreen:
Do you guys have an online reg set up these days?.. if so what is the link? All I found was for paper form and snail mail?...
Thanks for the fix-it info!
PostPosted: Mon Mar 07, 2011 6:43 pm
The link is in my previous post.
PostPosted: Mon Mar 07, 2011 9:26 pm
I stand corrected.
Mark Van Doren
San Juan 28
