It is currently Tue Mar 28, 2017 11:30 am
 Post subject: gudgeons pulled
PostPosted: Fri Apr 29, 2011 9:11 pm
Quick question for the repair gods...
While un-winterizing my 1977 h16 this spring, I noticed my top gudgeon has pulled from the transom. Both screws had drifted/pulled out. Not wanting to buy the newer one-piece unit, I'm thinking I simply need to tighten the screws...hopefully they are not stripped out.
If they aren't stripped and will re-tighten, can I put a dollop of West System followed by some 3M 5200 around the head for sealing?
If they are stripped, can I fill the old holes, re-drill, and do as aforementioned?
Thanks ya'll
bones
 Post subject: Re: gudgeons pulled
PostPosted: Sat Apr 30, 2011 6:22 am
Buy a 1/4-20 tap, #7 drill and some 1/4-20 stainless bolts
1. Drill holes
2. Rup tap through, very easy since it is aluminum
3. Insert bolts
