It is currently Tue Jan 16, 2018 7:23 am
PostPosted: Sun Jun 05, 2011 7:20 am
My 18 ft hobbie cat has 3 holes in the hulls. on the left hull there are 2 holes which are approximitly 6" in diameter. the right hull has one hole approximitly the same size. i have begun the repair work and will have pictures up in a couple of days. i need some advice on my repair work.
PostPosted: Sun Jun 05, 2011 7:21 pm
sailingchris wrote:
My 18 ft Hobie Cat has 3 holes in the hulls. On the port hull there are 2 holes which are approximately 6" in diameter. The starboard hull has one hole approximately the same size. i have begun the repair work and will have pictures up in a couple of days. i need some advice on my repair work.
I repaired your post. When you post the pictures, we'll be able to help.
