It is currently Wed Jan 17, 2018 2:57 am
 Post subject: Drying out a comp-tip
PostPosted: Mon Aug 01, 2011 8:10 pm
I just pulled a comp-tip out of mast to move to a different base and the foam inside the comp-tip is wet. I have no idea how deep the wetness goes. So...what's the best thing to do? I've heard of using gasoline to melt foam before. Should I do this to remove all the foam and then replace it with two-part foam?
thanks,
Mark
2007 Hobie Tiger
PostPosted: Tue Aug 02, 2011 4:36 am
Just leave it out in the sun for a few days.
Removing the foam with gasoline is extraordinarily dangerous. If you want to remove the foam, then use mechanical, not chemical means.
PostPosted: Tue Aug 02, 2011 8:52 am
how about a small fire :lol:
