It is currently Sun Apr 23, 2017 10:39 pm
PostPosted: Sat Aug 20, 2011 2:03 pm
I have a couple of small tears on the trampoline of my 2007 Getaway. Seems that the previous owner improperly laced the tramp and the cord made some cuts.
How can I repair them before the damage gets worse?? I was thinking of adding small strips of material in the pockets and then heat welding them in place...does this make sense?
PostPosted: Sat Aug 20, 2011 4:49 pm
Location: Latrobe, PA, USA *** Show YOUR Location - Edit Profile ! ***
Since the fabric is woven you could likely find some acceptable patch material and stitch it on using high-tensile thread. Spectra fishing line is available in up to 250# test and a variety of colors. I also recommend the Speedy Stitcher!
http://www.rei.com/product/602118/speedy-stitcher-sewing-awl
This is assuming that you don't mind removing the tramp for repair and reinstalling... I don't know about heat welding.
Raise your sail one foot, and you get ten feet of wind.
起你的一只帆,和你10英尺的。 -- Chinese Proverb
William D. Latinette @ Latrobe, PA, USA w. H14 Turbo X 2... wildlatin23@hotmail.com
PostPosted: Mon Aug 22, 2011 6:12 am
I never used it on the hobie but i use spectra when i need to sew anything that needs strength. I do WWII re-enactment and I have used it to sew up my HBT uniforms, Rips and tears in tents, and even to sew in a zipper in my fishing boat canvas. Your repair will last longer than the rest of your tramp for sure.
'73 hobie 16 restored 2011
'00 Seaswirl fishin boat
PostPosted: Fri Sep 02, 2011 6:26 am
Damnit...even when properly laced....the cord is still slipping over and cutting into the tramp. Is it too loose? I thought about adding some fibre/rubber washers along the rod to prevent this from happening.
PostPosted: Fri Sep 02, 2011 8:38 am
You could just cut a larger "V".
PostPosted: Fri Sep 02, 2011 10:45 am
lol...yes, that could work too!!! When cut, do I have to seal the edges to prevent fraying??
PostPosted: Fri Sep 02, 2011 12:25 pm
I'd guess that we don't, but you could try for good measure. Test on the part you cut off. Fibers are molded into the vinyl, so should not need it.
