It is currently Fri Jun 23, 2017 2:31 pm
PostPosted: Fri Aug 26, 2011 12:53 pm
I have a 14 hobie cat and I want to take the trampolene frame off of the hulls. I removed the bolts and two of them came right out but the other two are frozen in the holders with time and corrison. I put wd40 and oil around them but they want move at all. Does anyone have any suggistions on what to use?
PostPosted: Sun Aug 28, 2011 1:16 pm
You need penetrating oil ssuch as pb blaster. Spray it on and let it soak and respray over a few days.
2010 AHPC C2 #218
PostPosted: Fri Sep 09, 2011 1:51 pm
+1
Take your time, and maybe tap bolt head lightly with a hammer while twisting if you can.
1978 Hobie 16 (the new one)
1975 ish Hobie 16
Skype: kent.nothstine
PostPosted: Fri Sep 09, 2011 2:41 pm
Is it the 2 bolts you cannot remove or the corner casting from the pylon? If the latter, I had to use a rubber mallet and hit on the corner casting upwards to remove it. It would only budge a hair at a time, but it would move. It's an awkward angle to hit, so you can hit to hard either.
Marc...
