Removing and Reinstalling Hulls http://www.hobie.com/forums/viewtopic.php?f=20&t=3821 |
Author: | Alan Ellis [ Fri Jun 09, 2006 8:19 am ] |
Post subject: | Removing and Reinstalling Hulls |
1985 H16 Is there a trick to getting the hulls loose from the pylons? And....once I get them off, how do I get them back on? They seem awful tight and I don't want to damage them without knowing the proper way to remove and reinstall them. Thanks for the help. |
Author: | mmiller [ Fri Jun 09, 2006 1:24 pm ] |
Post subject: | Big hammer! |
Big hammer! We use a mallet called a "Dead Blow". This is a sand filled head. 2-5 lbs. We have had to use steel slege hammers with 2x4s too. Remove the pylon bolts. Loosen or remove the trampoline. Hammer in a upwards direction against the corner castings. Takes a considerable swing force in most cases. Hit each corner a bit then go to the next. Removing the frame as evenly as possible. |
Author: | Alan Ellis [ Fri Jun 09, 2006 2:34 pm ] |
Post subject: | |
Thanks. That's what I figured, but I wanted to make sure. What about getting it back on? Use the hammer and do the opposite? Thanks. AE |
Author: | Russ B [ Sat Jun 10, 2006 7:09 am ] |
Post subject: | |
Putting them back was the easy part for me. I cleaned off the inside of the castings and pylons really well and drove them back on with my dead-blow hammer. Beat on it right over the pylon and make sure it goes on evenly. I had to get my wife to hold the hull in position while I got them started. I laso opnly removed one side at a time. Did it frek you out cutting holes in your boat? |
Author: | Alan Ellis [ Sat Jun 10, 2006 7:19 am ] |
Post subject: | |
Russ B wrote: Did it freak you out cutting holes in your boat?
A little, but I knew it had to be done to do the repair correctly. The hulls are now off and I am letting the insides dry. I'll start on the glass-work in a day or so. Thanks for the response. AE |
