It is currently Fri Apr 19, 2024 1:49 pm
 Post subject: Hull repair suggestions
PostPosted: Wed Aug 13, 2003 6:36 am
The top of my hull is showing fiberglass. Any suggestion on how to temporarily fix this? Gelcoat, resin or something else? Haven't worked with gelcoat so not sure what to expect. Mainly just worried about water seeping into the hull. My long term plan would be to sand the hulls down and repaint (had delamination in front of pylons that I fixed).
Any suggestions would be appreciated. Thanks
 Post subject: Paint
PostPosted: Fri Aug 15, 2003 3:49 pm
Get a two part epoxy paint. Gel coat is not a good material for re-painting as it will not properly cure in an oxygen environment. It is a pain.
PostPosted: Mon Aug 18, 2003 7:27 am
How did you get the picture to post???????
Joe
Joe Fikentscher
www.jerseyplanning.com
 Post subject: Posting a picture...
PostPosted: Tue Aug 19, 2003 11:20 am
Use the "Img" ([img])%20button%20and%20then%20a%20URL%20for%20the%20image%20followed%20by%20the%20([/img]) button again. The image has to be hosted on a website somewhere.
