It is currently Thu Jun 22, 2017 9:51 am
PostPosted: Mon Mar 19, 2012 12:09 pm
I am finally getting around to rebuilding my rudders tonight. My plan is to sand them down with fine grit paper to get most of the nicks and scratches out, then give them a coat of PoliGlow. I have the older white-ish non-EPO rudders. They look plastic or fiberglass of some sort from a 1979 H16.
Will the PoliGlow work well on this material? Or is there something better to use? I really am not a fan of painting them, as I have never had good luck getting paint to stick to something like this.
Steve
1979 Hobie 16 "Orange Crusher"
PostPosted: Mon Mar 19, 2012 12:29 pm
most paint won't stick. However, I did try Krylon Fusion on mine last year and it seems to be hold well.
'73 hobie 16 restored 2011
'00 Seaswirl fishin boat
PostPosted: Mon Mar 19, 2012 2:09 pm
I'm planning on sanding mine to get them smooth and back to white and then I'm going to cover it in a few coats of Red Max Pro. Poliglow would work the same and should give it a nice original shine.
Zach
PostPosted: Mon Mar 19, 2012 2:15 pm
White-ish rudders from '79 are Lexan. Tougher than hell, and flexible like a noodle. Tough to get a good surface finish on them.
PostPosted: Mon Mar 19, 2012 2:23 pm
Thanks Matt.
So will the PoliGlow do anything for them? After sanding them, they seem 'open' like they need some sort of coating to protect them. Maybe just go over them with a heat gun to close the pores?
Steve
