Turning H16 over for keel repair http://www.hobie.com/forums/viewtopic.php?f=20&t=43 |
Author: | sail2relax1 [ Tue Jun 03, 2003 7:38 am ] |
Post subject: | Turning H16 over for keel repair |
Any one have any method on turing a H16 over so I can perform some keel repair. Short of tipping it up on one hull and letting it crash down. One catch, there will be no one around to help so I must do it single handed. |
Author: | Boat Slut [ Tue Jun 03, 2003 9:30 am ] |
Post subject: | |
I have turned my 16 over myself many times. lift the boat to its balance point and step to the other side and ease it down. It is much easier with some help if you can get it. |
Author: | chet [ Tue Jun 03, 2003 9:42 am ] |
Post subject: | Re: Turning H16 over for keel repair |
sail2relax1 wrote: Any one have any method on turing a H16 over so I can perform some keel repair.
Consider stepping the mast and laying the boat over on it's side. Not only will you avoid having to lower it to the ground while accomodating the crown of the front crossbar, it will be easier to return it to it's feet when you are done. |
Author: | hobiewon [ Wed Jun 04, 2003 10:42 am ] |
Post subject: | |
i usually just go sailing and the tipping over just seems to happen, maybe next time ill think about hull repair |
Author: | Hobie_Skipper1 [ Tue Nov 30, 2004 12:16 pm ] |
Post subject: | Just turned my Hobie 16 over this weekend... |
I need to do some keel repair over the off season. I dropped the boat off of the trailer onto the driveway (using some old pads from chairs for cushioning). I was then able to lift the Hobie 16 to it's balance point, step to the other side, and lower the boat carefully to the ground. I used chair pads to cushion the boat anywhere where it would be touching the ground. I then used some cheap furniture dollies from Home Depot and some 2x4s to place under the boat, so I could move it around easily in my garage to work on it... To summarize, pretty easy to do, but I helps to have some spare hands around while flipping it... |
Author: | rwehuman [ Tue Mar 01, 2005 10:44 am ] |
Post subject: | |
Just take the hulls off the tramp. its only two bolts per hull. Thats how I Serviced my boat's hulls. it was super simple. |
Author: | JaimeZX [ Tue Mar 01, 2005 11:09 am ] |
Post subject: | |
hobiewon wrote: i usually just go sailing and the tipping over just seems to happen, maybe next time ill think about hull repair
Author: | rwehuman [ Tue Mar 01, 2005 2:45 pm ] |
Post subject: | |
I'm saying you dont have to go through all that. One hull by its self is soooo much more manageable. brain fart now i got ya. duh I read that like i sail too fast, responded then re read it and feel like a tard. now it clicked thats a The "tow of shame" refrence.........very fittiing |
