It is currently Sat Jun 24, 2017 10:46 pm
PostPosted: Sun Jul 23, 2006 8:31 pm
Hi, Anyone has a lenght wise cut away view or diagram of a H16 hull??
I need to know how deep into the hull are the pylons installed at factory and what is supporting them at the keel inside the hull.
One of my decks depressed/flexed down around the base of the pylon! Before I cut and access hole on the side of the hull I need to know this.
thanks!
PostPosted: Mon Jul 24, 2006 7:12 am
These are on the site http://www.thebeachcats.com under "Pictures", "Technical", "Inside the Hobie 16"
PostPosted: Fri Sep 16, 2011 7:53 pm
This compression point seems to be the source of continuous hull cracking.
How about an injection of a high density closed cell foam around this point to distribute the loads more evenly?
Access is the problem too.
