It is currently Wed Nov 22, 2017 7:46 pm
 Post subject: Rudder Blade
PostPosted: Sun Jun 10, 2012 8:52 pm
Just got a 1982 14' Hobie Cat, the right rudder blade is broke in half. Where can I get a repalcement blade.
The hull # is: CCMC1678M82G
Can someone tell me anything about the hull #?
 Post subject: Re: Rudder Blade
PostPosted: Mon Jun 11, 2012 8:25 am
Hi csherwin7 - look for a replacement blade on eBay or Craig's List (buyer beware) or a Hobie Dealer http://www.hobiecat.com/support/dealers/search/ can ideally help you out.
I imagine you have the original EPO blades or Lexan blades so make sure you get the right kind to match your good blade.
Here's the info on your hull number:
http://www.hobiecat.com/support/article ... erial.html
Jonathan
'85 H16 __/) 87468 Tidal Wave
PostPosted: Tue Jun 12, 2012 11:00 am
FYI....The blade is the same for the 14, 16, 17, 18 (and maybe others?). The hole pattern is the same on the 14s and 16s, but the others are all different. Just thought I'd mention this since you'll see a lot more H-16 blades for sale, and they should work without modification.
Jerome Vaughan
Hobie 16
