It is currently Wed Jul 26, 2017 12:00 am
PostPosted: Sat Jul 07, 2012 7:24 pm
Hello,
When injecting Git Rot into the hull, do I have to first inject it deeper into the hull and then more shallow so that the Git Rot is in between both glass/foam joints or will the epoxy simply penetrate through the foam and join both layers of glass on either side to the foam no matter which depth I inject the epoxy into the hull?
-Janek
'72 Hobie 16
with
#56 Gonzo Nationals
PostPosted: Sat Jul 07, 2012 9:58 pm
Git Rot is pretty thin stuff. It should flow out between all the layers.
When I did my old 14 I pumped some in, took a break, mixed up a new batch and pumped some more in. Also when you start to see the git rot come up through the surrounding holes you can plug those off and force it in farther.
1980 H16
PostPosted: Sat Jul 07, 2012 10:23 pm
Thanks, that's great news. I was hoping i wouldn't have to somehow force it into the separate areas of delam.
'72 Hobie 16
with
#56 Gonzo Nationals
