It is currently Mon Jan 22, 2018 12:26 pm
PostPosted: Sun Aug 06, 2006 9:17 pm
I am looking into buying a H17 which has a broken socket (where the wing is inserted). The socket is cracked at the top and loose within the hull. How difficult is this to fix or should I keep looking for another 17?
 Post subject: Wing tube repair
PostPosted: Mon Aug 07, 2006 12:45 pm
You can install an inspection port near the tube and do glass work on the inside through that. Not hard work.
 Post subject: Re: Wing tube repair
PostPosted: Tue Oct 03, 2006 11:45 am
What Matt means is that it is not that hard if you're a contortionist and have really tiny hands :wink:
Actually, I posted some real detail on this process in the H17 forum, boiled down to this:
I repaired one and then beefed up the ones that are NOT broken so that they would not break later.
I put three hose clamps around the tubes, one in the middle, the other two are about 3 inches from top and bottom. I figured these would provide real structural strength.
I epoxyed 3 layers with glass cloth OVER the hose clamps.
IMPORTANT: after you cut the holes for the inspection ports, do NOT install the bezel until you are done fiberglassing. The extra 1/2 inch diameter on the hole makes a big difference in how much you can do.
Again - look around for other posts by me and you will find everything you wanted to know - and some stuff you didn't want to know too :oops: :lol:
