repair to fiberglass http://www.hobie.com/forums/viewtopic.php?f=20&t=47262 |
Author: | capron23 [ Fri Apr 19, 2013 8:46 am ] |
Post subject: | repair to fiberglass |
Just about to buy an old Hobie 16 cat and in one area a soft spot.....cracked and spongy. What is the best way to repair something like this. Cheers g |
Author: | PurdueZach [ Fri Apr 19, 2013 10:37 am ] |
Post subject: | Re: repair to fiberglass |
Welcome! Search the forum for "soft spot repair"- lots of information on this. |
Author: | srm [ Fri Apr 19, 2013 11:52 am ] |
capron23 wrote: Just about to buy an old Hobie 16 cat and in one area a soft spot.....cracked and spongy. What is the best way to repair something like this. Cheers g "Just about to buy" as in you haven't actually purchased it yet?? Perhaps you may want to rethink buying this particular boat. "Cracked and spongy" are not qualities you want to see when looking at used Hobies. If you haven't bought the boat yet, you may find it's in your best interest to keep looking for a better boat. The injection repair presented above works for small areas of delam. But if the area is cracked and spongy, that could likely mean that the fiberglass skins are fractured and the foam core is deteriorated and/or water logged. This could mean a more involved repair than simply squirting in some resin. sm |
Author: | GD_NC [ Fri Apr 19, 2013 11:59 am ] |
srm wrote: capron23 wrote: Just about to buy an old Hobie 16 cat and in one area a soft spot.....cracked and spongy. What is the best way to repair something like this. Cheers g "Just about to buy" as in you haven't actually purchased it yet?? Perhaps you may want to rethink buying this particular boat. "Cracked and spongy" are not qualities you want to see when looking at used Hobies. If you haven't bought the boat yet, you may find it's in your best interest to keep looking for a better boat. The injection repair presented above works for small areas of delam. But if the area is cracked and spongy, that could likely mean that the fiberglass skins are fractured and the foam core is deteriorated and/or water logged. This could mean a more involved repair than simply squirting in some resin. sm Run Away! There are lots of good 16s out there. Be picky. |
